  • Matt Taylor 873 posts 2086 karma points
    Nov 05, 2013 @ 11:09
    Matt Taylor
    How to call a Template or Razor script with Ajax?
    I've used Ajax before to call webmethods or base functions but I'd like to try using Ajax to call a Razor script which will generate some HTML and then display that HTML on my page.
    I'm looking for an exmple to show me how to do it.
    Regards,
    Matt
  • Ali Sheikh Taheri 470 posts 1648 karma points c-trib
    Nov 05, 2013 @ 12:49
    Ali Sheikh Taheri
    Hi Matt,
    If you are using Umbraco 6 then you can create an action in SurfaceController which returns the partial view. more here
    and if you are using Umbraco 4 the way I usually do it is that I create a template and with ajax request to that template. you dont need to create a page for it, just the template would be enough.
    hope it gives you some idea.
    Cheers
    Ali
    Nov 05, 2013 @ 13:45
    Matt Taylor
    Hi Ali,
    I'm using 6 with webforms.
    I've given it a quick test with the template and it looks pretty easy.
    With this script in my html (don't forget to add a reference to Jquery):
        $(function () {
            $('#Button').click(testScript);
        function testScript() {
            $.post("/mypage.aspx?altTemplate=AjaxTest",
            function (data) {
                alert(data);
    </script>
    and this in my AjaxTest template:
    <%@ Master Language="C#" MasterPageFile="~/umbraco/masterpages/default.master" AutoEventWireup="true" %>
    <asp:Content ContentPlaceHolderID="ContentPlaceHolderDefault" runat="server">
        <p>Hello</p>
    </asp:Content>
    the alert displayed the HTML from the template niceley.
    Regards, Matt
    Nov 05, 2013 @ 13:51
    Ali Sheikh Taheri
    Hi Matt,
    Glad it worked.
    you should be able to use the altTemplate like this:
    "/mypage.aspx/AjaxTest"
    this used to work on v4 but not sure about v6. could you try this too and let me know if that's still valid?
    Ali
    Nov 05, 2013 @ 14:47
    Matt Taylor
    No, that does not work.
    Maybe it's an MVC feature not webforms.
    Nov 05, 2013 @ 15:22
    Ali Sheikh Taheri
    Thanks for trying though :)
