  • Fredrik Esseen 610 posts 906 karma points
    Oct 19, 2009 @ 10:48
    Fredrik Esseen
    Using existing DB connection
    Ive created a table in the db where I want to store information when members is logged in so that I can display that in the back.
    How do I get the db connection from my Usercontrol? Ive tried to use the Mysql.Data as reference but then it complains about wrong reference..
    Oct 19, 2009 @ 11:03
    Rich Green
    You can use the connection string from the Web.Config file.
    Include a a reference to:
    using System.Configuration;
    Then something like this
    MyConnection.ConnectionString = ConfigurationManager.AppSettings["umbracoDbDSN"].ToString();
    Hope this helps.
    Rich
    Oct 19, 2009 @ 11:09
    Dirk De Grave
    You could also use the
    umbraco.BusinessLogic.Application.SqlHelper
    object (only to use if you're using the same umbraco database to store the info about member visits)
    /Dirk
    Oct 19, 2009 @ 12:04
    Fredrik Esseen
    Perfect!
    But I get an error: Keyword datalayer not supported.
    using
    System;
    using
    System.Collections.Generic;
    using
    System.Linq;
    using
    System.Web;
    using
    System.Web.UI;
    using
    System.Web.UI.WebControls;
    using
    System.Data;
    using
    umbraco.cms.businesslogic.member;
    using
    umbraco.cms.businesslogic.propertytype;
    using
    using
    MySql.Data;
    namespace
    NormalLogin
    public partial class NormalLogin : System.Web.UI.UserControl
    protected void Page_Load(object sender, EventArgs e)
    public void OnLoggedIn(object sender, EventArgs e)
    Member theMember = Member.GetCurrentMember();
    string constring = ConfigurationManager.AppSettings["umbracoDbDSN"].ToString();
    MySql.Data.MySqlClient.
    MySqlConnection mysqlcon = new MySql.Data.MySqlClient.MySqlConnection(constring);
    string sqlstr = "INSERT INTO MemberLog (MemberID) VALUES ('" + theMember.Id + "', '" + DateTime.Now + "')";
    MySqlDataAdapter mysqladapt = new MySql.Data.MySqlClient.MySqlDataAdapter(sqlstr, mysqlcon);
    mysqlcon.Close();
    Oct 19, 2009 @ 12:48
    Rich Green
    This may help debugging
    When testing usercontrols I test them outside Umbraco (unless using the API) by copying the database connection from the Umbraco site, creating a standard .NET page and then include the usercontrol within that, I can then debug that user control within Visual Studio as usual.
    Essentially it's just a standard web app as you're not using Umbraco functionality in your above code.
    Set that up and you should see your error pretty quickly?
    Oct 19, 2009 @ 12:57
    Fredrik Esseen
    I think the problem is that the connectionstring includes datalayer. Can that be it? And how do I work around it? Do I have to add a new key myself?
    Oct 19, 2009 @ 13:08
    Rich Green
    Try removing the "datalayer" part of your connection string.
    Oct 19, 2009 @ 13:26
    Dirk De Grave
    Or use the SqlHelper, it's designed to not worry about the datalayer part of the connection string!
    /Dirk
    Oct 19, 2009 @ 14:04
    Fredrik Esseen
    And how do I use the SqlHelper..?
    Oct 19, 2009 @ 14:16
    Dirk De Grave
    froad,
    Have a look at the msdn docs on http://umbraco.org/apiDocs/index.html
    ISqlHelper can be found in the umbraco.DataLayer namespace.
    /Dirk
    Oct 19, 2009 @ 14:29
    Fredrik Esseen
    Made it work..Thanks!
    Next problem...how do I get the current member? I tried following:
    Member
    But that didnt fetch anything..
    Oct 19, 2009 @ 14:43
    Dirk De Grave
    froad,
    Are you sure you're logged on, GetMember will only return a member object if logged on! And btw, you should be using the membership provider api over the existing member api. Details may be found on the wiki pages.
    /Dirk
    Oct 19, 2009 @ 14:45
    Fredrik Esseen
    Sorry to overwhelm you with questions before diggin in myself...
    Solved it this way:
    Member theMember = Member.GetMemberFromLoginName(HttpContext.Current.User.Identity.Name);
    Thank you for your time and advices!
    Oct 19, 2009 @ 15:05
    Fredrik Esseen
    Returning because it didnt work..
    //.aspx:
    asp:Login FailureText="Felaktigt anvndarnamn eller lsenord" OnLoggingIn="OnLoggedIn" ID="Login1" runat="server">
    string sqlstr = "INSERT INTO MemberLog (MemberID, LoggedInDate) VALUES
    + theMember.LoginName + "', '" + DateTime.Now + "')";
    Application.SqlHelper.ExecuteNonQuery(sqlstr);
    As you can see im trying to add the member to the log when he has logged in but the Identity.Name is empty. Why is that? I know im logged in because the page is only visible to logged in members!
    Oct 19, 2009 @ 15:16
    Fredrik Esseen
    Solved it in ´the not best way:
    Login1.UserName
    Why go for the cache when I had the answer in the login-control all the time :)
