Hi guys I'm wondering if you can help me again? I'm creating a website that allows users to enter values into a .net user control and when they press the save button it populates and saves and publishes a node in the umbraco back office. Once the user revisits the page to perform updates the fields in the .net user control are populated with those being stored in the node.
So far I have managed to complete this with any text values such as name, email etc but i am unsure how to achieve it with images.
The code i used for the text box values is as follows
Node currentPage = Node.GetCurrent(); // Take the values from the current umbraco node and display them to the user so they can be edited
txtName.Text = currentPage.GetProperty("Name").Value;
txtShortDescription.Text = currentPage.GetProperty("ShortDescription").Value;
txtFullDescription.Text = currentPage.GetProperty("FullDescription").Value;
// Take the values edited by the user and update the node in the umbraco backend
// Get the Document object via the nodefactory
Document currentPage = new Document(Node.GetCurrent().Id);
// Update the name of the node (text property)
currentPage.Text = txtName.Text;
currentPage.getProperty("Name").Value = txtName.Text;
currentPage.getProperty("ShortDescription").Value = txtShortDescription.Text;
currentPage.getProperty("FullDescription").Value = txtFullDescription.Text;
Like i said this all works perfect but im really struggling with working out how to allow the user to upload an image using a file upload control, store it in the node and when the user revisits the page, when the user control renders it pulls in the image that is stored in the node.
Any help would be great. I hope my explanation is clear.
If I remember correctly, then you can add a upload control to the user control, that will give you a HttpPostedFile object, which you can then set on a property like:
currentPage.getProperty("file").Value = fileObj;
If the datatype is = upload it should save the file on disk and save the path on the property
Yes that is correct i am currently using the old node factory API and the data type is set on the property is upload. The version of umbraco that I am, using is v6.1.6.
I'm wondering if you could elaborate further with regards to the httpPostedFile object and how I would use it? I'm fairly new to extending umbraco api through the use of .net user controls. I currently have a fileupload control on my user control called fileUploadVenueImage.
here is my code
//venue Information
FileUploadVenueImage.FileContent = currentPage.GetProperty("venueImage").Value; // How do I treat this as fileObj?
Hi guys still struggling with this uploading image query so any suggestions would be gratefully appreciated. The line of code below allows the user to upload an image via the user control and it updates the venue image property (datatype upload) with the file name of the image but doesnt write to the media folder. once it has been uploaded and it looks like this in the backoffice
Help using images with .net user controls
Paul
This is the old nodefactory api right?
If that doesnt work, then I'm positive that the new contentService does support this with SetValue(httppostedfile):
http://our.umbraco.org/documentation/Reference/Management-v6/Models/Content#SetValue(stringpropertyTypeAliasobjectvalue)
Hi Per,
Thanks for your response ;)
here is my code
Thanks and sorry if the answer is obvious.
Paul
However, if you upload an image via the backend it looks like this and it writes to the media folder
I really need a method to update the backend property with the contents of what the user has uploaded (not just the name) via the user control
Any suggestions?
Just cracked it by simply removing the .filename so my code now looks like this
What a dunce lol :) happy now tho!!
