  • Charles 42 posts 63 karma points
    Mar 16, 2014 @ 04:12
    Charles
    Changing Nodes properties only show up 1 time, and not after first change, Please Help
    Well, using Umbraco 4.6.1 here, and when I change the property of a Node, it shows up the first time, but than after changing it again, it doesn't change on the front end again. I can only change it once and it will show. I don't understand what I'm doing wrong here.
    So, I have a .cs file in the AppCode directory structure, and have controls using the function in the .cs files... like so:
    public static Content GetCached (Node aNode)
        Content theContent = new Content();
        try
            string theCacheKey = "Content:" + aNode.Id;
            if (System.Web.Hosting.HostingEnvironment.Cache[theCacheKey] == null)
                lock (_Lock)
                        theContent = Content.Parse(aNode);
                        System.Web.Hosting.HostingEnvironment.Cache.Insert(theCacheKey, theContent);
                        UmbracoHelper.AddCacheKey(theCacheKey);
            theContent = (Content)System.Web.Hosting.HostingEnvironment.Cache[theCacheKey];
        catch (Exception ex)
            ErrorHelper.LogError("Content:GetCached", ex);
        return theContent;
    I call upon the Node and it's properties like this:
    MMG.BusinessLayer.Content _Content = new MMG.BusinessLayer.Content();
    // Inside the function call is this:
    _Content    = MMG.BusinessLayer.Content.GetCached(Context.GetContent());
    And GetContent method looks like this:
    public static Node     GetContent  (this HttpContext aContext)
        if (aContext.Items["Content"] == null)
            Node theNode = new Node();
            try
                int theContentID = 0;
                if (int.TryParse(aContext.Request["cid"], out theContentID))
                    try
                        theNode = new Node(theContentID);
                        ErrorHelper.LogError("ContextExtensions:GetContent", ex);
                else
                    Location theLocation = aContext.GetLocation();
                    Node     theSiteNode = new Node(theLocation.ParentID);
                    foreach (Node theFolderNodes in theSiteNode.Children)
                        if (theFolderNodes.NodeTypeAlias == "Folder")
                            foreach (Node theChildNode in theFolderNodes.Children)
                                if (theChildNode.NodeTypeAlias == "Home")
                                    theNode = theChildNode;
                                    break;
            aContext.Items.Add("Content", theNode);
        return (Node)aContext.Items["Content"];
    What could be the problem?
    Mar 16, 2014 @ 04:47
    Charles
    Ok, so I found out something now. When I remove the lock (_Lock) statement, it updates fine everytime. That must be some sort of way they unlock the ability for the content to be updated.
    But where do I need to look to be able to figure out that part of the code?? Hmmmm, must be a GLOBAL variable of some sort somewhere.... hmmm
    In the declaration of that file, Content.cs, it says this:
    private static object   _Lock = "";
    Awwww, I believe it was there to lock any updating of content. Nice!!!
