Problem with the jCarousel and properties... Please help me out!
Hi everybody
I have succesfully downloaded and installed the jCarousel package by Gerty Engrie. But heres the problem:
For some reason I cant acces the "Properties" tab on the document type. It just shows nothing?? Anybody else had that problem? And if so, how do I solve it?
FYI. The problem is with the JCarousel POSITION data type rendering. Any tab after that control will not work properly. My guess is that the template for that control needs to change.
On a side note. TO fix, move that POSITION property to the GENERIC PROPERTIES tab, and you are good to go.
Hi everybody
