Problem with System.Data.Entity and DbContext MVC Umbraco 7
I'm trying to connect to the database in code behind of my Umbraco 7 MVC project.
I understand that I can use System.Data.Entity.DbContext for that eg.
public class umbracoDbDSN : DbContext
The thing is that my project doesn't see DbContext.
I added reference to System.Data.Entity both in references and in web.config assemblies. That didn't help.
So then also added EntityFramework.dll and in web.config as advised by different sources but still cannot make it working.
Basically project compiles successfully but I'm still getting DbContext cannot be found problem.
Hi, I'm trying to connect to the database in code behind of my Umbraco 7 MVC project.
I added reference to System.Data.Entity both in references and in web.config assemblies. That didn't help. So then also added EntityFramework.dll and in web.config as advised by different sources but still cannot make it working.
Any suggestions?
Thank you
Ok, solved :)
I followed this: http://www.nuget.org/packages/EntityFramework/
In short installed EntityFramework through NuGet Package Manager and it works
