  • Damian Green 452 posts 1433 karma points
    Aug 05, 2014 @ 16:33
    Damian Green
    Strange Property Initialisation Problem with Published Content Model and property delegeate
    Something completely baffling me here.
    I am using PublishedContentModel and have a doctype using it.
    On the doc type i have 2 properties. One property checks the other property and decides what to return.
    i.e.
    ShowSubDocs (bool)
    MenuProp
     - if (ShowSubDocs)
       - return children
    otherwise return some other menu structure
    The exact same code is running in dev and live. I have cleared the cache and republished the doc in question and the whole site yet the ShowSubDocs is always returning false on the live site.
    The last piece of the jigsaw is i used a bit of code i got from Morten's gist ( https://gist.github.com/sitereactor/6487186 )to get the property names by convention via a property delegate. (ill put a code dump below)
    If i use the name of the property instead of using the delegate it works ok. But when using the delegate it seems to be accessing the property before its been initialised * WHEN ACCESSING FROM THE CLASS * I say this because if i output the property on the view the correct value of true is returned.
    here is the class in question (with mortens property delegate example) :
     public class Base : PublishedContentModel, IBase
            #region Property Helpers
            protected readonly Func<MethodBase> Property = MethodBase.GetCurrentMethod;
            protected T Resolve<T>(MethodBase methodBase)
                var propertyTypeAlias = methodBase.ToUmbracoAlias();
                return Resolve<T>(propertyTypeAlias);
            protected T Resolve<T>(string propertyTypeAlias)
                return this.GetPropertyValue<T>(propertyTypeAlias);
            protected T Resolve<T>(MethodBase methodBase, T ifCannotConvert)
                return Resolve<T>(propertyTypeAlias, ifCannotConvert);
            protected T Resolve<T>(string propertyTypeAlias, T ifCannotConvert)
                return this.GetPropertyValue<T>(propertyTypeAlias, false, ifCannotConvert);
            protected T Resolve<T>(MethodBase methodBase, bool recursive, T ifCannotConvert)
                return Resolve<T>(propertyTypeAlias, recursive, ifCannotConvert);
            protected T Resolve<T>(string propertyTypeAlias, bool recursive, T ifCannotConvert)
                return this.GetPropertyValue<T>(propertyTypeAlias, recursive, ifCannotConvert);
            #endregion
            public Base(IPublishedContent content) : base(content)
    And this is my class that is showing the issue. I have removed surplus code to make it easier to read. This class inherits Base.
    public class Service : StandardContentPage
            public Service(IPublishedContent content) : base(content)
            public bool ShowAllServicesInMenu
                get { return Resolve<bool>(Property()); }
             public bool ShowAllServicesInMenu2
                get { return Resolve<bool>("ShowAllServicesInMenu"); }
            private bool xx = false;
            public bool XX
                get { return xx; }
            public List<Service> ServiceMenu
                get
                    xx = ShowAllServicesInMenu;
                    if (ShowAllServicesInMenu)
                        return this.Children<Service>().ToList();
                    //Get the items from the menu
                    var items = Resolve<IEnumerable<IPublishedContent>>(Property());
                    return items.Select(x => new Service(x)).ToList();
    The var XX was added to test the variable. And this shows true on dev and false on live. However if i access the menu properyt before accessing the XX propery then it shows true.
    Definitely seems to be a concurrency issue or something.
    ShowAllServicesInMenu2 - is the same property but uses a propert yname rather than delegate and always returns the right value when used in the class as shown above.
    Before i go and rip out the delegate and go back to good old typing the field name is there something going on here that is obvious and im missing it! But even more baffling is why the exact same code is behaving differently on live and dev!
    Thanks Damian
