My ProfileProvider has (among others) the following getter and setter:
[SettingsAllowAnonymous(false)]
public string description
get
var o = base.GetPropertyValue("description");
if (o == DBNull.Value)
return string.Empty;
return (string)o;
set
base.SetPropertyValue("description", value);
The custom Umbraco property alias is called "description" (in that casing). When I try to get the Profile for an Umbraco member of type "Ekspert", the decription method throws a NullReferenceException. I try to get the profile like this in my MVC controller (MemberProfile is my custom profile class):
Also, I get the same profile from this call, whether the supplied username exists in Umbraco or not, indicating that some basic setting/connection to Umbraco is missing.
Does it have something to do with my controller not inheriting from UmbracoController and thus not having an UmbracoContext?
Using UmbracoMemberProfileProvider in stand-alone ASP.NET MVC site
I'm trying to use Umbraco's Member functionality in a stand-alone ASP.NET MVC site. I've included the dlls from Umbraco 6.1.6 in the MVC project.
It works fine as long as I use the Members functionality for validating and logging in users on my MVC site.
But when I want to get and set the custom properties on my MemberType, I can't seem to get access to those.
My web.config for the MVC site looks like this:
<profile defaultProvider="UmbracoMemberProfileProvider" enabled="true" inherits="Business.Providers.MemberProfile"> <providers> <clear /> <add name="UmbracoMemberProfileProvider" type="umbraco.providers.members.UmbracoProfileProvider, umbraco.providers" /> </providers> </profile> <membership defaultProvider="CustomMemberProvider" userIsOnlineTimeWindow="15"> <providers> <clear /> <add name="CustomMemberProvider" type="Business.Providers.CustomMemberProvider" enablePasswordRetrieval="false" enablePasswordReset="false" requiresQuestionAndAnswer="false" defaultMemberTypeAlias="Ekspert" passwordFormat="Hashed" /> </providers> </membership> <roleManager enabled="true" defaultProvider="UmbracoRoleProvider"> <providers> <clear /> <add name="UmbracoRoleProvider" type="umbraco.providers.members.UmbracoRoleProvider" /> </providers>My ProfileProvider has (among others) the following getter and setter:
[SettingsAllowAnonymous(false)] public string description { get { var o = base.GetPropertyValue("description"); if (o == DBNull.Value) { return string.Empty; } return (string)o; } set { base.SetPropertyValue("description", value); } }The custom Umbraco property alias is called "description" (in that casing). When I try to get the Profile for an Umbraco member of type "Ekspert", the decription method throws a NullReferenceException. I try to get the profile like this in my MVC controller (MemberProfile is my custom profile class):
MemberProfile mp = MemberProfile.GetUserProfile("myUser")Also, I get the same profile from this call, whether the supplied username exists in Umbraco or not, indicating that some basic setting/connection to Umbraco is missing.
