  • vijay 129 posts 152 karma points
    Dec 22, 2009 @ 12:24
    vijay
    Problem with Member Logout?
    I am creating Login Page using user control.I am trying to login inside based on ID and Password.It is working fine,But when i log out it is not clear those id and pass word from cache.
    So next time i try to open login page it is redirecting page which will appear after successful login.
    Please send me any code to solve the problem.
    Thanks in advance,
    vijay.
  • Aaron Powell 1708 posts 3045 karma points c-trib
    Dec 22, 2009 @ 12:35
    Aaron Powell
    What version of Umbraco are you using? If you're using version 4 then you should just use the ASP.NET controls for logging in/ logging out.
    Check the cookies, that's the most likely place that isn't being cleared. Firefox has a number of good plugins (eg - Firecookie) which allow you to see the cookies on a site
  • Tom Madden 252 posts 454 karma points MVP 4x c-trib
    Feb 16, 2011 @ 10:27
    Tom Madden
    Although late, I came across the same issue and solved it with this code:
                Member m = Member.GetCurrentMember();
                Member.RemoveMemberFromCache(m);
                Member.ClearMemberFromClient(m);
                Response.Redirect("/");
    It's the ClearMemberFromClient method that removes the necessary cookie from the client.
  • kows 81 posts 151 karma points c-trib
    Feb 16, 2011 @ 10:36
    kows
    what way do you use for loggin in?
    i always do it like this:
    if (Membership.ValidateUser(account.Email, account.PassWord))
        FormsAuthentication.SetAuthCookie(account.Email, false);
       Response.Redirect(umbraco.library.NiceUrl(Node.GetCurrent().Id));
       protected void LsStatus_LoggedOut(object sender, EventArgs e)
           FormsAuthentication.SignOut();
    this with custommembershiprovider.
