Is there a way to create properties programmatically for a Document type using IContent. I also want to be able to rename properites.
I've come across a post using the Legacy Document object but want to use the new IContent object.
Thanks in Advance
Laith
Hi Laith,
Welcome to our!
I think you can do this with the ContentTypeService:
https://our.umbraco.org/documentation/Reference/Management-v6/Services/ContentTypeService
Hope this helps,
Best,
Sören
Programatically Create/Rename Properties for a Document Type using IContent
Thanks in Advance
Laith
Hi Laith,
Welcome to our!
Hope this helps,
Best,
Sören
