Partial view macro not working in RTE - Error is Failed to retrieve macro result for macro with alias
I have a simple partial view macro that I'm using to render YouTube embed code in to the RTE. When I add it though, I get an error "Failed to retrieve macro result for macro with alias". In the logs I get an error "Error loading Partial View (file: ~/Views/MacroPartials/YouTubeVideo.cshtml). Exception: System.ArgumentNullException: Value cannot be null. Parameter name: content"
Are you using MVC or Webforms? And have you tried having a look in the /App_Data/Logs file? It should contain more detailed information about the specific error related to the macro.
Is there a specific reason why you need to use a partial view macro in the RTE to show a YouTube video, instead of you use the built in embed function in the RTE. It can take YouTube videos.
One reason is I want to wrap the iframe embed code with a parent tag that makes the player responsive and fixes some formatting. Also, the built in embed insists on a width and height which I don't want.
Either way, it would be nice to know why it isn't working. I found a bug report of something that is fairly similar: http://issues.umbraco.org/issue/U4-3789
Thanks Dennis. The approach Chris is using is the same as mine though.
I have since discovered that when i add the macro to the RTE, if I check the network panel in firefox I can see umbraco trying to hit the following URL but it is getting a 404 (not found) back:
I have no problem to get this to work on the frontend of the website with this code snippet. I have added the macro paramter called videoID, as type textbox.
@if (Model.MacroParameters["videoID"] != null){
var fullLink = Model.MacroParameters["videoID"].ToString(); var youTubeId = fullLink.Split('=').Last();
But in the backend i will just get this macro Alias: YouTube in a yellow dotted box. Did you remember to add the parameter to the macro, and make sure that the alias is videoID. casing is very important herre.
The macro code is:
Any ideas what is going wrong. It often works ok if I publish straight away but always fails on first load or when I preview it.
Using Umbraco version 7.1.4
Thanks!
Hi Ian
Using MVC. The more detailed message from the logs is the 2nd one shown above.
Hi IanS,
Hope this helps,
/Dennis
Hi Dennis
Hi IanS,
Okay that make sense, try to see this thread about the same topic perhaps you can use the same approach as Chris. https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/61268-Umbraco-Grid-editor,-YouTube,-and-Bootstrap
Hope this helps,
/Dennis
Hi Ian
Ah, sorry missed that - Looked like the error one usually get's when seeing the error in the browser.
So you should probably just check if there has been set a value before trying to render the iframe code.
/umbraco/backoffice/UmbracoApi/Macro/GetMacroResultAsHtmlForEditor?macroAlias=YouTubevideo&pageId=-1¯oParams%5B0%5D.key=videoID¯oParams%5B0%5D.value=1234567
Should this page exist? I can't find it in my installation although it is referenced in these scripts:
\umbraco\Js\umbraco.resources.js
umbraco\Js\umbraco.services.js
Seems like a common issue. Not sure if anyone has found a solution yet.
https://our.umbraco.org/forum/core/general/48713-Missing-backoffice-path
https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/53775-Not-getting-macro-params-in-macro-partial-view-from-custom-macro-parameter-datatype
https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/53884-Insertupdate-macro-problem?p=1
Hi IanS,
I just think that your partial view macro file, just need to contain this snippet of code.
Hope this helps,
/Dennis
Thanks again. Have just tried that but unfortunately still getting the 404 error
Hi IanS,
Hope this helps,
/Dennis
Hi Dennis.
Yes I've added the parameter to the macro with the alias in the correct case and set as a textbox field. The 404 error I get is:
This file doesn't exist for me. Should it? If not, there must be some custom routing.
I've tried the latest build of Umbraco and this is still happening. Must be a bug then.
