  • Vrushank 11 posts 61 karma points
    Jun 01, 2015 @ 06:58
    Vrushank
    Urlrewriting problem
    I have an issue with UrlRewriting.
    Below is my rule.
    <add name="301/xyz"  virtualUrl="/xyz" destinationUrl="/abc" redirectMode="Permanent"  redirect="Domain" ignoreCase="true" rewriteUrlParameter="IncludeQueryStringForRewrite"  />
    I want to redirect xyz page to abc page.That is working fine. But when /xyz/123 url comes then it is not working proper.
    Can anyone help me?
    And I'm using Umbraco 6.0.5.
    Regards, Vrushank
  • Urvish 252 posts 776 karma points
    Jun 01, 2015 @ 07:03
    Urvish
    Hi Vrushank,
    You can put $ in end of the virtual url.
    It will consider exact url means that is end of url.
    Your code would be like below.
    <add
     name="301/xyz"
     virtualUrl="/xyz$"
     redirect="Domain"
     ignoreCase="true"
    Check below code. It is working or not.
    Hope this wil help.
    Regards,
    Urvish Mandaliya
    Jun 01, 2015 @ 07:12
    Vrushank
    Thank you Urvish Mandaliya for the reply.
    This is working like a charm. It makes my day.
    Thanks.
