I'm trying to create a member but are receiving this weird error.
Umbraco.Core.Services.IMemberService' does not contain a definition for 'Save'
My API code
var newmember = ApplicationContext.Current.Services.MemberService.CreateMember(user.email, user.email, user.name, "MyGift"); ApplicationContext.Current.Services.MemberService.Save(newmember, false);
What am I missing?
Hi Anton,
This code works fine for me:
Services.MemberService.Save(currentMember);
Yeah it is damn strange . I can see the fuction in intellisence but it crashes at runtime
was member created successfully?
Is your user object a dynamic? I had a similar issue but for GetByEmail when I was passing in user.Email where user was a dynamic object I had created by parsing JSON. In my case, casting the properties to string seemed to make it work.
user
GetByEmail
user.Email
My API code
What am I missing?
Hi Anton,
Is your
userobject a dynamic? I had a similar issue but forGetByEmailwhen I was passing inuser.Emailwhereuserwas a dynamic object I had created by parsing JSON. In my case, casting the properties to string seemed to make it work.is working on a reply...
