Using Member.GetCurrentMember() on extension less url
I have the following method in a user control.
if i go to "/dataroom" it doesn't works however if i add the ".aspx" extension it works. Any thoughts on how to get this working on extensionless url's.
public static string GetUserName()
if (Member.GetCurrentMember() != null)
return Member.GetCurrentMember().LoginName;
return "";
public static string GetUserName() { if (Member.GetCurrentMember() != null) { return Member.GetCurrentMember().LoginName; } return ""; }is working on a reply...
