Our client is running Umbraco 4.7.2. After they started to use Internet Explorer 11, they cannot create links anymore (for texts or images) in TinyMCE. I suspect an upgrade of TinyMCE is needed (https://tracker.moodle.org/browse/MDL-43312). Has anyone done this for Umbraco 4.7.2? Is it possible?
Thank you Dave! So an upgrade of TinyMCE seems to be the way forward.
But I guess upgrading the TinyMCE-version means that you have to incorporate the Umbraco-specific changes afterwards. Is there anyone out there that have those documented?
I've seen that there is a file named "umbraco-implementation-notes.txt" in the tinymce-folder, but it would be great to have a more in depth guide.
Links in TinyMCE not working with Umbraco 4.7.2 and IE11
Thanks for any input!
Kind regards Jessica
Hi Jesssica,
Of course 4.7.2 is a old version.
I found this forum topic about IE11 and tinyMce. Maybe there is something in there that can help you out : https://our.umbraco.org/forum/ourumb-dev-forum/bugs/29911-RTE-doesn%27t-work-in-FF11?p=0
Dave
Or maybe this blog post can help you out : https://blog.fynydd.com/updating-tinymce-in-umbraco/
EDIT : make sure you get 3.x version of the tinyMce here : http://archive.tinymce.com/download/older.php
Dave
According to this blogpost : https://blog.fynydd.com/updating-tinymce-in-umbraco/ it should be fairly easy.
dave
