  • sony 11 posts 111 karma points notactivated
    Feb 07, 2016 @ 14:45
    sony
    How to show Node Names with same order as it is in Umbraco backoffice using Examine Search?
    Hello Support,
    In umbaco backend the Nodes Order is:
    ItemsA
    item1
    item2
    item3
    ItemsB
    item4
    item5
    imte6
    I am using this code :
    @if (!string.IsNullOrEmpty(Request.QueryString["q"])) {
    this code is not working properly.
    Output should be out same as Umbraco backend:
    ItemsA
    item1
    item2
    item3
    ItemsB
    item4
    item5
    imte6
    Thanks.
  • Anders Bjerner 487 posts 2996 karma points MVP 8x admin c-trib
    Feb 07, 2016 @ 22:20
    Anders Bjerner
    Try something along this way:
    @foreach (var result in Umbraco.TypedSearch(Request.QueryString["q"]).OrderBy(x => x.SortOrder)) {
        <p>@result.Name (@result.SortOrder)</p>
    It of course only works if the results are in the same folder.
    Feb 08, 2016 @ 06:00
    sony
    Thanks for reply Anders.
    I have used this but it works for same parent folder.
    But in this case result is coming from multiple folders and sort order not working there.
    It should be look like this :
    1. ItemsA
       item1
       item2
       item3
    2. ItemsB
      item4
      item5
      imte6
    ItemsA and ItemsB are parent folders.
    thanks.
    Feb 08, 2016 @ 08:48
    Ismail Mayat
    Sony,
    You will have to group them first using by parent then do Anders suggestion of sort.
    Regards
    Ismail
