How to work with Ajax to call surface controller's method in Umbraco 7.3.5 ? Previously in Umbraco 7.2 i used like this: $.ajax({ type: "POST", data: "{'searchString':'@searchString ','pageS':' @pageS ','pageSize':' @pageSize '}", url: "/umbraco/Surface/{controller Name}/{method Name}/", contentType: "application/json; charset=utf-8", dataType: "json", success: function (response) { } });
But now(7.3.5) its showing path not found error to the controller's method . Thanks in Advance...
I'm still using 7.2 so I can't test it but if it's a path problem maybe you can try using
@Url.Action("actionName", "ControllerName")
It will generate a fully qualified url to the action.
Thanks for your reply Rick... I did small mistake in dll reference thats why ajax call is not worked. my above code working properly in 7.3.5 too.
Ajax call to surface controller in umbraco7.3.5
$.ajax({
type: "POST",
dataType: "json",
