  • Michael Petersen 6 posts 26 karma points
    Mar 13, 2010 @ 13:57
    Michael Petersen
    /Base problems
    Hello
    I'm trying to work with the /Base function, but I can't get it to work. The only thing I can get is <error>Extension not found or permission denied</error>
    I have follow the example http://umbraco.org/documentation/books/introduction-to-base/simple-base-samples and watch the tutorial video.
    I can't figur out what the problem is, so I hope someone can help me.
    Thank you in advance
    My configuration:
    umbraco v 4.0.3
    Windows 7 IIS 7.5 (same problem on Windows 2008 IIS 7)
  • Jesper Hauge 298 posts 487 karma points c-trib
    Mar 13, 2010 @ 14:27
    Jesper Hauge
    Try to check out the wiki instead, it's a bit more verbose:
    http://our.umbraco.org/wiki/reference/umbraco-base
    Regards
    Jesper Hauge
  • amunk 17 posts 32 karma points
    Mar 13, 2010 @ 14:59
    amunk
    I have played a little bit with /base and found out that the Urls are case-sensitive (!!?!) It is because the types and methods are called directly using the case in the Url.
    Have you entered your Urls in the right case?
    Regards,
    Anders
