  • lingjing 28 posts 45 karma points
    May 04, 2010 @ 04:22
    lingjing
    Problem with register my own dll
    Hi All. I created a .Net libary project. It looks like below:
    namespace MyNamespace
      public class XXX
    In the umbraco, I try to register this dll file and call it inside my template like below:
    <%@ Import Namespace="MyNamespace" %>
    <script runat="server" Language="C#">
     protected void Page_Load(object sender, EventArgs e)
    </script>
    Can anyone tell me how I can add the reference of my dll file into umbraco? I try "xsltExtensions.config", but it does not seems working.
    Thank you
    jing
  • atze187 160 posts 215 karma points
    May 04, 2010 @ 08:34
    atze187
    2
    "xsltExtensions.config" is the wrong place to go for, you need to copy the dll file to the bin folder and change the line
    to
    <%@ Import Namespace="MyNamespace" Assembly="MyNamespace.dll" %>
    André
    May 04, 2010 @ 13:41
    atze187
    Damnit, I mixed up @Import and @Register. The Import-directive does not support the assembly attribute.
    But you need to copy your dll file to the bin folder.
    May 04, 2010 @ 23:05
    lingjing
    Hi Andre
    Thanks for reply, I did copy my dll file to the bin folder. but it does not work.
    Jing
