I wonder if it's possible to use an xslt macro withing a custom aspx page/custom section?
I'd basically like to transform an external xml file and display the results within a custom admin section. Does anyone have any experience doing this or any tips?
If I understand correctly, in your custom section/page, you have an XML data-source (external, being not from Umbraco). So yes, you can apply an XSLT to that, no problem. But my question is do you need to use a macro for it?
I'm not sure what benefits there are to using a macro in that way - when all you need to do is transform an XML document with the XSLT. If you need extension libraries (like umbraco.library), then you can load those in as required.
Do you need an example code snippet to help? (which language are you developing in?)
Using an xslt macro in a custom section
Hi All
Dan
Hi Dan,
Cheers, Lee.
