  • Lee 1130 posts 3088 karma points
    Jul 07, 2010 @ 11:06
    Lee
    IE Login Problem
    Just had the strangest problem!
    I have a usercontrol/macro that has a normal .NET LoginControl, I have it on a normal Umbraco page and if I use Chrome, Firerfox, Opera, Safari it works fine.  I click login and I either login or get an error message for incorrect credentials etc..
    BUT it will not work in IE?? (I'm using IE8) .. If I click the login button, nothing happens? I'm miffed at the moment... Just wondering if anyone else has had similar issues?
    Jul 07, 2010 @ 11:56
    Lee Kelleher
    Hi Lee,
    What type of control are you using for the submit button? Is it a Button or ImageButton?
    I've heard cases where ImageButton can cause a problem and not trigger the OnClick event.
    Cheers, Lee.
    Jul 07, 2010 @ 11:57
    Lee
    Its a button fella?  Its just a normal loginControl which is why I'm a little miffed :S
    Jul 07, 2010 @ 12:07
    Lee Kelleher
    Hmmm... any other JavaScript errors in IE?
    Found this:  http://forums.asp.net/t/1121401.aspx  - suggestions are that it could be related to Google AdSense? But there are a few other suggestions on that forum topics too!
    Good luck! Lee.
    Jul 07, 2010 @ 12:45
    Lee
    FIXED!! And you will not believe what it was........
    I am putting this solution here in case anyone else has the same issue!!
    So I had a standard login control and I had no JS errors but when you clicked the login button nothing happened in IE, but worked in Chrome fine got error messages etc......
    After looking through the source, I noticed one of my JavaScript includes was being self closed as it was in an XSLT macro (Here is part of the XSLT)
    <script src="{$currentPage/ancestor-or-self::node [string(data [@alias = 'areaJavaScript'])!=''] [position()=1] /data [@alias = 'areaJavaScript']}" type="text/javascript"></script>
    And it was producing
    <script src="/scripts/my.js" type="text/javascript" />
    I changed the code to
    <script src="{$currentPage/ancestor-or-self::node [string(data [@alias = 'areaJavaScript'])!=''] [position()=1] /data [@alias = 'areaJavaScript']}" type="text/javascript"><xsl:text> </xsl:text></script>
    And now it works fine in IE!!  How frustrating....  This caused the login control to just not work!!
    Jul 07, 2010 @ 12:47
    Lee Kelleher
    Hip-hip-hurray!
    Bet you love XSLT even more now? ;-) LOL
    Glad you got it sorted Lee - if only you could mark your own reply as the solution!
    Cheers, Lee.
    Jul 07, 2010 @ 12:53
    Lee
    lol indeed I don't love it ;)  Yeah now you are all powerful MVP n' all, can't you suggest that feature to the 'firm'
    Jul 07, 2010 @ 12:59
    Lee Kelleher
    If only!  But that's a specific XSLT issue, not even a bug really. Frustrating I know.
    Take a look at the ComplianceFilter for Umbraco module, it might be what you're looking for?
    http://compfilter4umbraco.codeplex.com/
    It will try to revert all the self-closing tags, apart from <img>, <hr> and <br>, etc.  Not sure if it works with v4.5, but it's a HttpModule, so I see no reason why not.
    Cheers, Lee.
  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Jul 07, 2010 @ 18:04
    Tim
    Yup, IE will also throw a fit if you have a self closing DIV as well (even though its technically valid).
