  • Razvan 36 posts 67 karma points
    Nov 18, 2010 @ 13:07
    Razvan
    uComponents - MultiNodePicker - LINQ serialization problem
    Hello everybody,
       I have a strange problem with the LINQ and the datatype MultiNodePicker from uComponents. The data stored by this control is in the following format
     <MultiNodePicker>    <nodeId>1102</nodeId>    <nodeId>1096</nodeId>    <nodeId>1164</nodeId>    <nodeId>1166</nodeId>    <nodeId>1170</nodeId>  </MultiNodePicker>
      But using linq it returns 11021096116411661170.
      I don't know if its a problem related to uComponents or umbraco.ling.
    Have a good day
    Nov 18, 2010 @ 13:10
    Jeroen Breuer
    That's a bug in LINQ to Umbraco. It's because LINQ to Umbraco can't read properties which are stored as XML. Please vote for this issue: http://umbraco.codeplex.com/workitem/28731.
    If you use the MNTP and store the data as cvs it should work.
    Jeroen
    Nov 18, 2010 @ 13:16
    Razvan
    Thanks for the quick reply Jeroes. I voted for this bug. The data comes from a custom control (http://ucomponents.codeplex.com/) and I don't want to change/recompile the control. What does MNTP mean ?
    Nov 18, 2010 @ 13:21
    Lee Kelleher
    MNTP = Multi-node Tree Picker
    Nov 18, 2010 @ 13:22
    Jeroen Breuer
    MNTP means MultiNodeTreePicker. It's the datatype from uComponents you're using :). In the prevalue configuration of the datatype you can say how the value needs to be stored. See this for more info: http://ucomponents.codeplex.com/wikipage?title=MultiNodeTreePicker&referringTitle=Documentation
    Jeroen
    Nov 18, 2010 @ 13:26
    Razvan
    Thanks, I will convert my code to use CSV. But I hope this XML issue will be fixed in the next versions of umbraco.
    Nov 18, 2010 @ 13:28
    Rich Green
    2
    Razvan,
    As Jeroen mentions, you can configure the Multi Tree Node Picker to hold it's values as CSV instead of XML, you need to change the selection in the datatype
    Rich
    Nov 18, 2010 @ 13:29
    Rich Green
    you got it already :)
    Feb 17, 2011 @ 13:45
    Jeroen Breuer
    This has been solved in Umbraco 4.6 because you can now also read xml properties with LinqToUmbraco :).
    Jeroen
