  • Niels Kristiansen 166 posts 382 karma points
    Nov 25, 2010 @ 15:36
    Niels Kristiansen
    Help to create a .LESS package
    Is there anyone who could help me out, creating a .LESS package?
    I can see how I take the dll into the package, but I can't find a way to place a code in the web.config, that depends on the IIS.
    If it's IIS6 you need to place one code and if it's IIS7 another code.
    The reason for making this package is mostly to have a easy integration for webdesigners and not that technical minded people :)
    Kind regards,
    Niels Kristiansen
