Is there anyone who could help me out, creating a .LESS package?
I can see how I take the dll into the package, but I can't find a way to place a code in the web.config, that depends on the IIS. If it's IIS6 you need to place one code and if it's IIS7 another code.
The reason for making this package is mostly to have a easy integration for webdesigners and not that technical minded people :)
I haven't got the time for it, though I got the information from Matt. What I did instead is I have placed a step-by-step tutorial how to only implement .LESS into Umbraco.
I followed the tutorial and added/extended the Less viewer from ubootstrap and compiled a new package. Check out uLess if you want an easy to install package with the ability to Add/Delete less files on the server from back office.
This is my first umbraco package so should I add the link to the wiki page, or is that a no-no?
Help to create a .LESS package
Kind regards,
Niels Kristiansen
Hey Niels,
You'll want to create a package action for this, luckily you can find one that does just this in the package actions contrib project:
http://packageactioncontrib.codeplex.com/SourceControl/changeset/view/54419#530900
You'll want to copy it to your project, and then setup the action in the package actions tab in the create package process.
Any problems, let us know.
Matt
Comment author was deleted
Hi Niels,
Have you had any luck creating this .LESS-package? I would love to see it...
Kenneth
Hi Kenneth,
The tutorial is placed right here:
http://our.umbraco.org/wiki/recommendations/recommended-reading-for-web-developers/less-and-integration-into-umbraco
Hopefully I get the time to make a .LESS package in the new year or if anyone else is up for it, can follow mine or Matts tutorial.
Hope that can help you,
Niels
Justin
