I want to build small intranet solution with Umbraco with following features:
-some small c# usercontrols that will display some data from SQL into grids.
-file sharing functionality.
-wiki & and howto documents.
-Active directory integration.
If I understood well the permision for front-users can be setup with members group and role base protection.
For AD integration I have seen 2 methods but both has some lacks.
1 - Change web.config to AD membershiprovider - but the problem is that it is not possible to setup member groups because the members are not displayed.
i saw your post here and was wondering if eventually you did use umbraco for your intranet solution. I'm actually looking for the same kind of solution.
i do not know if it is still topical, if yes, may be that will be https://our.umbraco.org/projects/collaboration/uintra/ interesting for you. we are using Umbraco for set of success Intranets for our client for our company internally. we integrated it with AD, CRMs, asp.net membership and so on... u are welcome free to contact me, if you have questions.
Umbraco Intranet Solution and AD
2 - Custom login usercontrol and using DirectoryServices to authenticate users and automatically create members assign group , enum membership (for example : http://our.umbraco.org/wiki/how-tos/membership-providers/use-active-directory-to-authenticate-site-members-(intranet) but the problem with this method that the media folders are not protected and can be accesed with direct link.
Any suggestions ?
hello,
thx for your reply
hallo,
vadym
https://docs.uintra.com/getting-started/membership-Inettegration page did not find detailed information on how to sign in with Active Directory. Will you update the page?
