As far as I'm aware, to rebuild the Examine/Lucene index, you'll need to republish at least one of the content nodes - hopefully that should kick-start it?
I knocked together a little utility you can grab it here extract the files to your usercontrols directory then in your dashboard.config add the following:
When you log into the backend under developer section all your indexes will be listed with a button to rebuild next to it, clicking that will fire up the rebuild process.
I installed it after I added a new value to ExcludeNodeTypes in the ExamineIndex.config but found the pages of the type I had added were still being found in the search.
I rebuilt the index as instructed but found that no search results would appear until I had performed a publish of the home node and all its subpages.
Rebuild Examine Index
Hi there,
is there a way to explicitly rebuld the examine index?
I deleted the examine index-directory, restartet IIS & the app-pool and exmine will generate its new directories with
/Index
and
/Queue
in it and generates the .exa and .lck files BUT the queue remains empty and so the index will not be refreshed.
shuoldn't it generate a .add file in the queue for each node in the CMS? Why does this not happen? Any Ideas?
therse are my settings from the examinesettings file:
<add name="MyIndexer" type="UmbracoExamine.MemberLuceneExamineIndexer, UmbracoExamine"
runAsync="true"
supportUnpublished="false"
supportProtected="true"
interval="60"
analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net"
indexSet="MyIndexSet"/>
and
<add name="MySearcher" type="UmbracoExamine.LuceneExamineSearcher, UmbracoExamine"
analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net" enableLeadingWildcards="true"
and the ones in the examineIndex.config:
<IndexSet SetName="MyIndexSet" IndexPath="~/data/ExamineIndexes/de/MyIndexSet/" IndexParentId="2077">
<IndexAttributeFields>
<add Name="id" />
<!-- REQUIRED -->
<add Name="nodeName" />
<!-- REQUIRED -->
<add Name="updateDate" />
<add Name="releaseDate" />
<add Name="contentDate" />
<add Name="writerName" />
<add Name="path" />
<add Name="nodeTypeAlias" />
<!-- REQUIRED -->
<add Name="parentID"/>
<add Name="niceUrl"/>
<add Name="umbracoNiceUrl"/>
<add Name="version"/>
<add Name="pressId"/>
<add Name="isAdHoc"/>
</IndexAttributeFields>
<IndexUserFields />
<IncludeNodeTypes />
<ExcludeNodeTypes />
</IndexSet>
I run Umbraco 4.5.2 and Examine 1.0
Kind regards
Christo
ok, i have it:
<add name="MyIndexer" type="UmbracoExamine.MemberLuceneExamineIndexer, UmbracoExamine"...
is wrong. it's pointing to the wrong indexer. should be:
LuceneExamineIndexer instead ( too much copy&paste i guess :-)
Hi Christo,
Cheers, Lee.
Thats true, or just empty up the index folder. But anyway, my mistake was a wrong configuration, which didn't let the indexing start.
thanks
Christo,
<section id="developer"> <areas> <area>developer</area> </areas> <tab caption="Umbraco examine"> <control>/usercontrols/ExamineIndexAdmin.ascx</control> </tab> </section>When you log into the backend under developer section all your indexes will be listed with a button to rebuild next to it, clicking that will fire up the rebuild process.
Regards
Ismail
Hey thats a smart idea Ismail
thanks - I'll give it a try
Ismail -
It'd be great if you could get that on the our.umbraco.org. It's really helpful, and I'm sure a ton of people could use it.
-C
Chad,
Released as package see http://our.umbraco.org/projects/backoffice-extensions/examine-index-admin dont forget to vote if you like it.
Regards
Ismail
So the magic is done by:
ExamineManager.Instance.IndexProviderCollection[indexToRebuild].RebuildIndex();
that's exactly what I was looking for.
thanks Ismail
Thanks for this package.
Is that right?
I'm still finding my way about Examine.
Thanks.
Thanks Ismail it works!
I am wondering, why doesn't Umbraco update the indexes automatically when you edit and publish content..??
I am trying to implement ExamineManager.Instance.IndexProviderCollection[indexToRebuild].RebuildIndex();
When the site loads due to issue:
https://our.umbraco.org/forum/using-umbraco-and-getting-started/84748-examine-not-rebuilding-after-cmsimport
Can this be done please?
