  • Yovav Gad 41 posts 62 karma points
    Jan 06, 2011 @ 02:04
    Yovav Gad
    obout grid control is not working when running under Umbraco
    I’m getting an error when trying to bind an obout grid under Umbraco
    Does anyone have a fix for this or do you know what can I do to resolve it ?
    I’ve just downloaded your latest obout version from January 5th, 2011 but still get this error,
    (it works fine if I run it on an external page – not under Umbraco)
    Please let me know if you have any suggestion.
    The Controls collection cannot be modified because the control contains code blocks (i.e. <% ... %>).
    Exception Details: System.Web.HttpException: The Controls collection cannot be modified because the control contains code blocks (i.e. <% ... %>).
    Stack Trace
    at System.Web.UI.ControlCollection.Add(Control child)
    at Obout.Grid.Grid.CreateReferencesForAppearanceResources()
    at Obout.Grid.Grid.CreateChildControls(IEnumerable dataSource, Boolean dataBinding)
    at System.Web.UI.WebControls.CompositeDataBoundControl.PerformDataBinding(IEnumerable data)
    at Obout.Grid.Grid.ExecuteRebinding(Boolean forced)
    at Obout.Grid.Grid.RaisePostDataChangedEvent()
    at System.Web.UI.Page.RaiseChangedEvents()
    at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
  • Aaron Powell 1708 posts 3046 karma points c-trib
    Jan 06, 2011 @ 02:19
    Aaron Powell
    Are you adding it via a macro? If so you can't have inline code in the ASCX file from what I recall.
    Jan 06, 2011 @ 17:09
    Yovav Gad
    I also tried loading the user control directly (with no macro) but I get the same results.
    Jan 06, 2011 @ 17:45
    Yovav Gad
    Solved thanks to Chris from obout.
    We had a head tag with runat="server" that caused it
    <head runat="server"> changed to just <head>
    I think there is a dynamic script injection somewhere, I'll try using <%# instead of <%=
