  • Jesper Ordrup 1019 posts 1528 karma points MVP
    Jan 20, 2011 @ 16:28
    Jesper Ordrup
    Using Umbraco with webmatrix
    How do you get an existing Umbraco 4.6.1 site to work with WebMatrix deploy?
    Ive got most of it working. I've copied site+db to a local installation and it runs fine within webmatrix. Publishing works almost - only thing missing is configuring db. Problem is that the settings dialog does not allow me to add a connect string?
    When looking at "databases" in Webmatrix I can see a major difference from the Webmatrix installed Umbraco site. There's no database registered - even though the site works locally.
    /Jesper
    Jan 20, 2011 @ 22:54
