Process information: Process ID: 8696 Process name: w3wp.exe Account name: NT AUTHORITY\NETWORK SERVICE Exception information: Exception type: ReflectionTypeLoadException Exception message: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information. at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module) at System.Reflection.Assembly.GetTypes() at umbraco.BusinessLogic.Utils.TypeFinder.FindClassesMarkedWithAttribute(Type attribute) at umbraco.presentation.umbracobase.restExtension..ctor(String extensionAlias, String methodName) at umbraco.presentation.umbracobase.requestModule.httpApp_PostAcquireRequestState(Object sender, EventArgs e) at System.Web.HttpApplication.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Request information: Request URL: http://umbraco.ateatmp.plakat.se/default.aspx Request path: /default.aspx User host address: 192.168.170.63 User: Is authenticated: False Authentication Type: Thread account name: NT AUTHORITY\NETWORK SERVICE Thread information: Thread ID: 6 Thread account name: NT AUTHORITY\NETWORK SERVICE Is impersonating: False Stack trace: at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module) at System.Reflection.Assembly.GetTypes() at umbraco.BusinessLogic.Utils.TypeFinder.FindClassesMarkedWithAttribute(Type attribute) at umbraco.presentation.umbracobase.restExtension..ctor(String extensionAlias, String methodName) at umbraco.presentation.umbracobase.requestModule.httpApp_PostAcquireRequestState(Object sender, EventArgs e) at System.Web.HttpApplication.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Hey Keith, thanks for the tip, but I did not succeed to get it working... in Full trust it works fine, it is just the Medium trust where it fails.. I can see you run Umbraco in Full trust
Hi I am having the same problem when I deployed the site in a IIS 6 Server 2003. I tried to add <trust level="Full" /> under <trust level="Full" /> but still the same problem, could any one help with please.
/Base HELP! Unhandled Exception Umbraco 4.6.1
I have installed Umbraco on a Windows Web Server 2008 R2 and it works but not /base.
I have copied the same files to my local machine and everything is working fine including base.
I have no idea whats stopping this code from running on my webserver?
Does hanyone have any ideas i can try?
I get an eventlog trace :
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 2011-01-25 15:49:59
Event time (UTC): 2011-01-25 14:49:59
Event ID: d5db0f8dcc294bdbbdb340d910dd5235
Event sequence: 3
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/63/ROOT-1-129404405972922783
Trust level: Full
Application Virtual Path: /
Application Path: C:\inetpub\wwwroot\umbraco.ateatmp.plakat.se\
Machine name: WEBDEV
Process ID: 8696
User:
Thread information:
Thread ID: 6
Hey,
I have the same error running on godaddy shared hosting, medium trust.
/Julius Bartkus
Hi Julius,
I installed MVC 3.0 and added a few WebConfig entries to fix this
<runtime>
<!-- Old asp.net ajax assembly bindings -->
<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
<dependentAssembly>
<assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" />
<bindingRedirect oldVersion="1.0.0.0-2.0.0.0" newVersion="3.0.0.0" />
</dependentAssembly>
Hey Keith,
hey,
I have created a workitem on codeplex
http://umbraco.codeplex.com/workitem/29996
