  • Gaurav 12 posts 32 karma points
    Feb 05, 2011 @ 11:00
    Gaurav
    When I choose "Create" command for Order node in [commerce] - Umbraco CMS error was generated.
    Hi all,
              I am using commerece for umbraco and this error to be come in admin section When I chose "Create" command for Order node in [commerce] - Umbraco
    ERROR CREATING CONTROL FOR NODETYPE: initorders
    Exception Details: System.ArgumentException: ERROR CREATING CONTROL FOR NODETYPE: initorders
    Source Error:
    Stack Trace:
    [ArgumentException: ERROR CREATING CONTROL FOR NODETYPE: initorders]
       umbraco.cms.presentation.Create.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\presentation\umbraco\create.aspx.cs:45
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
       System.Web.UI.Control.OnLoad(EventArgs e) +99
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\businesslogic\BasePages\BasePage.cs:287
       System.Web.UI.Control.LoadRecursive() +50
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
    Version Information: Microsoft .NET Framework Version:2.0.50727.3053; ASP.NET Version:2.0.50727.3072
