I have a question regarding Umbraco membership. Is it possible to access membership table and synchronize it with other SQL database table using connection string or vice versa.
Where is this information kept in Umbraco database?
Also, I created a member today and add custom field "City" in member profile. I wanted to see where this field information is kept in DB but could not find it.
Could you please explain?
Is it also possible, for arguments sake, to use ASP.NET membership DB instead of Umbraco membership DB if I use ASP.NET usercontrols?
Accessing membership info in DB + adding custom info.
Thank you.
write a custom membershipprovider / roleprovider then you can write your own save/update/delete/... methods for your members
