  • jivan thapa 194 posts 681 karma points
    Mar 25, 2011 @ 09:11
    jivan thapa
    Can not create DocumentType Using console application
    HI, I am new to umbraco.
    I try to create Document type using console application. but it says
    Value cannot be null.
    public int CreateNewDocumentType(string title, string alias, string description)
                User u = new User(0);
                DocumentType newDocument = DocumentType.MakeNew(u, "aasds");
               // newDocument.Alias = alias;
                newDocument.Description = description;
                newDocument.IconUrl = "doc.png";
                newDocument.Save();
                    Document.RePublishAll();
                return DocumentType.GetByAlias(alias).Id;
                return 0;
    Jivan
  • Richard Soeteman 4052 posts 12925 karma points MVP 2x
    Mar 25, 2011 @ 10:38
    Richard Soeteman
    Hi Jivan
    The document needs an HttpContext  so you can't create documents via a Console App. You can use a Webservice though.
    Richard
    Mar 25, 2011 @ 11:17
    jivan thapa
    thanks, Richard.
    what if i want to create DocumentType?
    Does webservice can create Document Type?
    Regards
    JIvan
