using Umbraco Unser control wrapper to create a data type
using Umbraco Unser control wrapper to create a data type that will allow to create nodes edit and update from a single gridview component , the nodes will be a document type under another parent node document type i will be able to edit, add, modify those items by showing their list in gridview ,,
any links ir examples wil be useful
If your requirement is just to add multiple contents in a single then you can use Repeatable Custom content http://our.umbraco.org/projects/backoffice-extensions/repeatable-custom-content
Pnima
And you can also use Embedded content.
Jeroen
