  • Bex 444 posts 555 karma points
    Apr 21, 2011 @ 17:35
    Bex
    First Package - usercontrols not copying across!
    Hi!
    I have created my first package.. it's a very simple one that contains 2 usercontrols and some dlls, the package appears to create fine and I have some actions to create a db table and update the dashboard.
    When I install the package everything happens except the usercontrol does not appear in the new site. (it's definitely been added to the package as I checked the zip file!) Even the macro gets created.. just the usercontrol isn't there!
    I created the package in 4.5.2  and also this is the version I am installing to!
    What's happening?
    Bex
    Apr 21, 2011 @ 17:38
    Hi Bex
    That's odd...don't know if there may have been set some obscure permissions on that specific file for some weird reason perhaps? :-)
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Apr 21, 2011 @ 23:25
    Richard Soeteman
    I would check the UmbracoLog table whenever something is wronmg during install it gets logged there.
    Richard
