  • dimi309 245 posts 579 karma points
    May 26, 2011 @ 14:39
    dimi309
    Examine multiple nodes problem
    Hello everyone,
    I am trying to set up Examine with our site, on Umbraco 4.7. I have set up the index set, the indexer and the searcher.
    However only two files get created in the index folder: segments.gen, and segments_1 and using Luke I can see that nothing gets indexed. I keep getting the following error in umbracoLog:
    Error adding to SiteMapProvider: System.InvalidOperationException: Multiple nodes with the same URL '/' were found. XmlSiteMapProvider requires that sitemap nodes have unique URLs.     at System.Web.StaticSiteMapProvider.AddNode(SiteMapNode node, SiteMapNode parentNode)     at umbraco.presentation.nodeFactory.UmbracoSiteMapProvider.loadNodes(String parentId, SiteMapNode parentNode)
    I have republished all my nodes, and I have ever written an xslt procedure to output all Urls. There are no two '/' paths anywhere.
    I have read about such problems from other entries in the forum and, as I have mentioned I have tried to follow the information given there, but nothing seems to work in my case. Would someone happen to have an idea about what I can do?
    May 26, 2011 @ 16:59
    dimi309
    Apparently this was a configuration error on my part. Everything works well now. Sorry for posting a question so fast.
    By the way, if anyone is starting out with Examine, I would strongly suggest the following package :)
    http://our.umbraco.org/projects/backoffice-extensions/examine-index-admin
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Oct 07, 2011 @ 17:51
    Tim
    Hi Dimitri,
    I'm having a similar problem, what did you do to solve it?
    Oct 07, 2011 @ 18:32
    dimi309
    Hi Tim!
    From what I remember it was a very silly mistake on my part. I think I had declared my search indexer in ExamineSettings.config as UmbracoMemberIndexer instead of UmbracoContentIndexer, or done something like that.
    Best regards,
    Dimitri
