  • Aximili 177 posts 278 karma points
    Jun 14, 2011 @ 05:15
    Aximili
    Examine Index is not updated automatically
    When I edit a page and publish it, the examine index is not updated, hence search results are always out of date.
    I have searched this forum and tried editing ExamineSettings.config, removing analyzer and setting runAsync to false. It didn't help.
    I found some people posted the code to update the index, but that's not the solution I am after. Shouldn't the index be updated automatically everytime you update the content?
  • Jon Boyer 37 posts 59 karma points
    Jan 24, 2012 @ 22:14
    Jon Boyer
    Was there ever a solution to this?
    Jan 24, 2012 @ 23:30
    Aximili
    Hi Jon,
    This is what I ended up doing
    umbraco.content.AfterUpdateDocumentCache += new umbraco.content.DocumentCacheEventHandler(content_AfterUpdateDocumentCache);
    private void content_AfterUpdateDocumentCache(Document sender, umbraco.cms.businesslogic.DocumentCacheEventArgs e)
    // Rebuild SiteSearchIndexer (Search results will be updated after a few minutes)
    ExamineManager.Instance.IndexProviderCollection["SiteSearchIndexer"].RebuildIndex();
    Jan 24, 2012 @ 23:47
    Jon Boyer
    Thanks Hardi!
    Um...this is going to sound stupid.  Which file does that code actually go in?
    Jan 25, 2012 @ 01:46
    Aximili
    You can create a new class like this :)
    using System;
    using umbraco.BusinessLogic;
    using umbraco.cms.businesslogic.web;
    using Examine;
    using System.Text.RegularExpressions;
    using System.Web;
    using umbraco.controls;
    public class UmbracoEvents: ApplicationBase
    /// <summary>Constructor</summary>
    public UmbracoEvents()
    privatevoid content_AfterUpdateDocumentCache(Document sender, umbraco.cms.businesslogic.DocumentCacheEventArgs e)
    Jan 31, 2012 @ 22:02
    Jon Boyer
    That appears to have worked nicely.
    Thank you!
