"Could not load file or assembly 'UrlRewritingNet.UrlRewriter' or one of its dependencies. The system cannot find the file specified."
Has anybody had much experience with SUMO? It sounds pretty cool but there is hardly any info or documentation as far as I can tell.
I had a previous error where it didn't copy the installer.ascx file to the correct place so I manually copied the file which seemed to work, but now when I try load '/SUMO/default.aspx' I get the error above.
Silverlight for Umbraco Media Objects SUMO problem
I'm trying to get Silverlight for Umbraco Media Objects (SUMO) - http://our.umbraco.org/projects/website-utilities/silverlight-for-umbraco-media-objects-%28sumo%29 - to work on an Umbraco 4.6 install. The site is already up and running using UrlRewriting but now when I try to run SUMO I get the following error:
Thanks.
