I have deleted the other forum posts, which was about the same topic as this one. Please don't post in multiple categories since it's considered to spam the forum - If you're in doubt about the category just place it in the one you think is the best fit. If there is a better category for the post one of the administrators in here will make sure to move it :-)
SocialFront Problem
Hi how to use Social Front in umbraco.
I have downloaded and installed Social front but not able to create a new social networking website.
Thakns in advance.
Hi Abhisek
Now let's have a look at your question...
What version of Umbraco are you trying to install the package on? And have you had a look at the Umbraco specific package, which is found here? http://our.umbraco.org/projects/collaboration/socialfront-for-umbraco
Hi Jan,
Sorry for that multiple posts. I was not aware and new to this website.
I am using Umbraco 4.7.0 and Social Front 0.1.1.
I have downlaoded Social Front on my system. Than in umbraco i have used Install Local package for using this Social Front library.
It gives new SF Package2 under Installed Pacakge.
Now i can see all Social Front template in new pop up window.
My problem is how to create now my social networking website, using all these templates.
I think SocialFront is only tested with 4.0.1, 4.0.2 & 4.0.3 so I'm not sure it will work on 4.7 (new schema etc).
I have tried on 4.0.1,4.0.2 & 4.0.3 but i am not able to create social network website.
Can you elaborate with these version...
