I've created a custom datatype but the save Method doens't always work. When I press the save button the value is saved, but when I press the save and publish button it saves the value just once. When I change the value again and save it the value isn't being saved anymore. So after the save and publish button is pressed neither the save or save and publish button work anymore. Here is my save code:
[code]
public void Save()
this._data.Value = _tribalDatepicker.Text;
[/code]
When I debug the _tribalDatepicker.Text is always the value I typed in the textbox, but after the save and publish button the value in _tribalDatepicker.Text is the previous value and not the value I typed in. Is this an Umbraco bug or does anybody know how this can be solved?
Never had issues with Custom Datatypes, but when you add a Breakpoint on the Save Method? Is that Breakpoint Hit every time.
Richard[/quote]
Yes the breakpoint is hit every time, but sometimes the value of _tribalDatepicker.Text is not the value I entered in the textbox, but the pervious saved value.
Can it be that something else is updating the Value? I haven't experience any of these problems so maybe it's popssible to submit the full source of the code to the forum and people can look at it for you?
[quote=rsoeteman]Can it be that something else is updating the Value? I haven't experience any of these problems so maybe it's popssible to submit the full source of the code to the forum and people can look at it for you?
Richard[/quote]
Here is the source code:
UmbdtDatepicker.cs
[code]
using System;
using System.Text;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.HtmlControls;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Xml;
using umbraco.DataLayer;
using umbraco.BusinessLogic;
using umbraco.editorControls;
using umbraco.controls;
using TribalControls;
namespace TribalUmbraco.DataTypes
public class UmbdtDatepicker: umbraco.cms.businesslogic.datatype.BaseDataType, umbraco.interfaces.IDataType
private umbraco.interfaces.IDataEditor Editor;
private umbraco.interfaces.IData _baseData;
private UmbdtDatepickerPrevalueEditor _prevalueeditor;
public override umbraco.interfaces.IDataEditor DataEditor
get
if (Editor == null) Editor = new UmbdtDatepickerDataEditor(Data);
return _Editor;
public override umbraco.interfaces.IData Data
get
if (baseData == null) baseData = new umbraco.cms.businesslogic.datatype.DefaultData(this);
return _baseData;
public override Guid Id
get {
return new Guid("bfeb08d3-1db9-4e83-85b6-3de5c828d52e");
public override string DataTypeName
get
return "[Tribal] Datepicker";
public override umbraco.interfaces.IDataPrevalue PrevalueEditor
get
if (prevalueeditor == null) prevalueeditor = new UmbdtDatepickerPrevalueEditor(this);
return _prevalueeditor;
// This class will define/render/load/save the datatype settings
public class UmbdtDatepickerPrevalueEditor : System.Web.UI.WebControls.PlaceHolder, umbraco.interfaces.IDataPrevalue
#region IDataPrevalue Members
tribalDatepicker = new TribalDatepicker();
_tribalDatepicker.ID = ControlId("DpCurrentDatePicker");
_tribalDatepicker.TribalDateTime = DateTime.Today;
// set selected value if data was saved before
if (!String.IsNullOrEmpty(data.Value.ToString()))
{ tribalDatepicker.TribalDateTime = Convert.ToDateTime(data.Value);
//// add datatype value controls to data editor
base.ContentTemplateContainer.Controls.Add(tribalDatepicker);
[/code]
TribalDatepicker.cs
[code]
using System;
using System.ComponentModel;
using System.Collections;
using System.Collections.Specialized;
using System.Globalization;
using umbraco;
public string CustomMinutes
set { _minutes = value.Split(", ".ToCharArray()); }
public bool EmptyDateAsDefault
set { _emptyDateAsDefault = value; }
public bool ShowTime
set { _showTime = value; }
get { return _showTime; }
public string GlobalizationAlias
set { _globalAlias = value; }
get { return _globalAlias; }
/// Bepaald de tijd die getoond wordt in de textbox.
[Bindable(true),
Category("Appearance"),
DefaultValue("")]
public DateTime TribalDateTime
get
return _datetime;
/// Als een datum ongeldig is wordt deze op false gezet zodat een foutmelding getoond wordt.
public bool DatetimeNotValid
get
return _datetimeNotValid;
set
_datetimeNotValid = value;
protected override void OnInit(EventArgs e)
if (this.ShowTime)
dateFormatJs += " %H:%M";
dateFormatNet += " HH:mm";
dateFormatJsSelect = ",\n" +
" showsTime : true,\n" +
" timeFormat : 24 \n";
//Voeg al het javascript toe aan de pagina.
Page.ClientScript.RegisterClientScriptBlock(Page.GetType(), "datepickerWithPopup", "
/// Render this control to the output parameter specified.
/// The HTML writer to write out to
protected override void Render(HtmlTextWriter output)
//Toon de textbox met de kalender erachter.
base.Render(output);
output.WriteLine("");
if (DatetimeNotValid)
output.WriteLine("De datum was ongeldig en is daarom terug gezet op vandaag.");
if (!Page.IsPostBack)
{ tribalDatepicker = new TribalDatepicker();
base.ContentTemplateContainer.Controls.Add(_tribalDatepicker);
[/code]
The reason you get the error is beacuse you need to recreate the object again in the OnInit Method. The only thing that you can surround with Page.IsPostBack is setting of the Date Value.
[/code]
I've also peaked at the code that you submitted and I see one Catch block that doesn't do anything when setting the TribalDatTime Value. Maybe set a breakpoint there?
[code]public DateTime TribalDateTime
get
return _datetime;
_tribalDatepicker.TribalDateTime = Convert.ToDateTime(data.Value);
[/code]
Custom datatype save problem [SOLVED]
[code]
public void Save()
[/code]
Richard
[quote=rsoeteman]Hi,
Richard[/quote]
Richard
Richard[/quote]
UmbdtDatepicker.cs
[code]
using System;
using System.Text;
using System.Web;
using System.Xml;
get
if (Editor == null)
return _Editor;
get
return _baseData;
get {
get
get
// referenced datatype
private umbraco.cms.businesslogic.datatype.BaseDataType _datatype;
// constructor
public UmbdtDatepickerPrevalueEditor (umbraco.cms.businesslogic.datatype.BaseDataType DataType)
_datatype = DataType;
public Control Editor
get
return this;
protected override void OnLoad(EventArgs e)
base.OnLoad(e);
public void Save()
#endregion
public static ISqlHelper SqlHelper
get
return Application.SqlHelper;
public class UmbdtDatepickerDataEditor : System.Web.UI.UpdatePanel, umbraco.interfaces.IDataEditor
private umbraco.interfaces.IData _data;
// datatype DataEditor controls
private TribalDatepicker _tribalDatepicker;
public UmbdtDatepickerDataEditor(umbraco.interfaces.IData Data)
_data = Data;
public virtual bool TreatAsRichTextEditor
get { return false; }
public bool ShowLabel
get { return true; }
get { return this; }
public void Save()
DateTime newDate;
if (DateTime.TryParse(tribalDatepicker.Text, out newDate))
this.data.Value = _tribalDatepicker.Text;
_tribalDatepicker.DatetimeNotValid = false;
else
this.data.Value = string.Format("{0:yyyy-MM-dd}", DateTime.Today);
_tribalDatepicker.DatetimeNotValid = true;
public string ControlId(string name)
return string.Concat(name, ((umbraco.cms.businesslogic.datatype.DefaultData)data).PropertyId.ToString());
base.OnInit(e);
[/code]
TribalDatepicker.cs
[code]
using System;
using umbraco;
namespace TribalControls
/// Summary description for datePicker.
[DefaultProperty("Text"),
ToolboxData("<{0}:datePicker runat=server>")]
public class TribalDatepicker : TextBox
private DateTime _datetime;
private bool _showTime = false;
private bool _emptyDateAsDefault = false;
private bool _datetimeNotValid = false;
private string[] _minutes = { "00", "15", "30", "45" };
private string[] _hours = { "--", "00", "01", "02", "03", "04", "05", "06", "07", "08", "09", "10", "11", "12", "13", "14", "15", "16", "17", "18", "19", "20", "21", "22", "23" };
private string[] _days = { "--", "1", "2", "3", "4", "5", "6", "7", "8", "9", "10", "11", "12", "13", "14", "15", "16", "17", "18", "19", "20", "21", "22", "23", "24", "25", "26", "27", "28", "29", "30", "31" };
private ArrayList _months = new ArrayList();
private ArrayList _years = new ArrayList();
private string _globalAlias = "nl-NL";
private string dateFormatJs = "%Y-%m-%d";
private string dateFormatNet = "yyyy-MM-dd";
private string dateFormatJsSelect = "";
[Bindable(true),
DefaultValue("")]
get
return _datetime;
set
try
_datetime = value;
this.Text = string.Format("{0:yyyy-MM-dd}", _datetime);
catch
get
set
if (this.ShowTime)
Page.ClientScript.RegisterClientScriptBlock(Page.GetType(), "datepickerWithPopup", "");
Page.ClientScript.RegisterClientScriptBlock(Page.GetType(), "datepickerWithPopupHelper", "");
Page.ClientScript.RegisterClientScriptBlock(Page.GetType(), "datepickerWithPopupLang", "");
Page.ClientScript.RegisterClientScriptBlock(Page.GetType(), "datepickerWithPopSkin", "");
base.OnInit(e);
output.WriteLine("
string strSetup = " Calendar.setup({" +
" inputField : \"" + this.ClientID + "\",\n" +
" ifFormat : \"" + dateFormatJs + "\",\n" +
" displayArea : \"" + this.ClientID + "showe\",\n" +
" daFormat : \"" + dateFormatJs + "\",\n" +
" button : \"" + this.ClientID + "ftriggere\",\n" +
" singleClick : true\n" +
dateFormatJsSelect +
try
if (ScriptManager.GetCurrent(Page).IsInAsyncPostBack)
ScriptManager.RegisterClientScriptBlock(this, this.GetType(), "Calendar.Setup" + this.ClientID, strSetup, true);
else
Page.ClientScript.RegisterStartupScript(this.GetType(), "Calendar.Setup" + this.ClientID, strSetup, true);
catch
private string markMinute(int minute)
int _currentDiff = 100;
int _currentMinute = 0;
System.Collections.ArrayList _localMinutes = new ArrayList();
foreach (string s in _minutes)
_localMinutes.Add(s);
_localMinutes.Add("60");
foreach (string s in _localMinutes)
if (s.Trim() != "")
if (currentDiff > Math.Abs(int.Parse(s) - minute))
currentMinute = int.Parse(s);
_currentDiff = Math.Abs(int.Parse(s) - minute);
if (currentMinute == 60)
return "00";
else
if (_currentMinute.ToString().Length == 1)
return "0" + _currentMinute.ToString();
else
return _currentMinute.ToString();
[/code]
The TribalDatapicker.cs is an adapted version of the datePicker I found in the Umbraco Source code.
Could it be OnInit on your DataEditor that sets the value before it gets saved?
Just a thought, try surrounding it with a if(!IsPostBack)
Edit: Maybe that's not needed anyway...
[quote=fed]Could it be OnInit on your DataEditor that sets the value before it gets saved?
Edit: Maybe that's not needed anyway...[/quote]
I tried surrounding it with a if(!IsPostBack), but then I get an "object reference not set to an instance of an object" error when I try to save.
[code]
base.OnInit(e);
[/code]
Why it's not needed anyway?
[code]
base.OnInit(e);
[/code]
get
return _datetime;
set
try
_datetime = value;
catch
[/code]
Thank you Richard! Everything is working now.
Here is my code.
[code]
private umbraco.interfaces.IData data;
_data = Data;
_tribalDatepicker = new TribalDatepicker();
public void Save()
DateTime newDate;
else
base.OnInit(e);
[/code]
