  • Max Mumford 266 posts 293 karma points
    Sep 13, 2011 @ 11:33
    Max Mumford
    Running macro according to requested page's path
    Hi all,
    I have created a macro that redirects the user to a change password page according to whether or not a property on their member node is set to true. I then inserted this macro into the top most template so it is executed on every page.
    The problem is, The user still needs to be able to use the logout page, so I need to tell it not to run if it is on the "/members/logout" page.
    I have tried the following but all have failed:
    • Using the "HttpContext.Current.Request.Url.AbsolutePath" variable to check for the "/members/login" page
    • Adding the macro into a content placeholder's default content on the top most master page and clearing this default content by manually inserting content into the placeholder on the logout page
    What is the best way to achieve this?
    Max.
    Sep 14, 2011 @ 16:23
    Max Mumford
    bump
    Sep 21, 2011 @ 16:42
    Max Mumford
    bumpity bump
