  • TomK 7 posts 37 karma points
    Nov 11, 2011 @ 09:57
    TomK
    Examine Index Problem after update from 4.5.2 to 4.7.1
    i have implemented a searchcontrol in my site. After updating umbraco to 4.7.1 it stop to work well.
    i think the new generated Examine Index is now Casesensitive.
    There is no change in ExamineSettings.config and Examine.Index.config.
    Any Hints for me..
  • James Drever 118 posts 149 karma points
    Nov 11, 2011 @ 10:12
    James Drever
    Hi Tom,
    Which analyzer are you using?  My understanding is that the WhitespaceAnalyzer is case sensitive, but the StandardAnalyzer is NOT case sensitve - see http://our.umbraco.org/forum/developers/extending-umbraco/14449-Examine-Search-Incase-sensitive  When I changed my analyzer for my custom index to use Standard in ExamineSettings, it worked fine.  (I'm presuming you are using a custom index?  I think the Internal index was deliberately configured to use Whitespace and shouldn't be changed.)
    James.
    Nov 11, 2011 @ 11:12
    TomK
    Hi James,
    this solve my problem. Crazy that the WhitespaceAnalyzer works in 4.5.2 Incase-sensitve!?!?
    Tom
  • priya 25 posts 45 karma points
    Jan 05, 2012 @ 13:07
    priya
    I have also upgraded umbraco from 4.0.3 to 4.7.1..Everything is working fine but in memebers during the search
    only for one of the member its not working and showing"KEY is not found in the Dictionary".
    any Hints for the problem ????????
