I added manage hostname "/english" in "English" content, i set up this content for English Language Site.
Content "Link to Document" is working fine no problem, problem is with alternative links. Umbraco just added http:// +"HostName" + "link to Document" without main domain name so that I can't browse content link using alternative links.
What happens if you just click the /english.aspx right next to the text "link to document" what url do you then get? And could you post it in here perhaps?
Alternative Links problem.
For example
"Linke to Document" is /education.aspx
Alternative links is http:///english/education.aspx
browser can not open http:///english/education.aspx page. Alternative link should be like http://localhost:9091/english/education.aspx to open.
Any suggessions?
thank you Very much
Jivan
Hi Jivan
Have you entered "/english" in the "Manage hostnames" dialogue in Umbraco? In that case you just need to remove "/".
thank you Jan for your time.
I tried by replacing "/" from manage hostnames. I also re-publish all nodes after that. Still its not working............
Any Idea?
Have you also added the hostname (english) in the hosts file? The file is found in this path: C:\Windows\System32\drivers\etc\hosts
Hi, Jan.
I am working on server. it is not in localhost.
What changes should I make on server in order to work "manage hostnames" ?
thank you so much
Jivan
Hi Jivan
