I'm using EF to remove a record from the database on "Document.BeforeDelete" and I'm getting this error:
The
type 'System.Data.Objects.ObjectContext' is defined in an assembly that
is not referenced. You must add a reference to assembly
'System.Data.Entity, Version=4.0.0.0, Culture=neutral,
PublicKeyToken=b77a5c561934e089'.
This error is errorneous as I do reference the System.Data.Entity assembly in my project.
I was able to resolve the above issue by adding this reference <add assembly="System.Data.Entity, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> to the <compilation><assemblies> section in the web.config. however the Document.BeforeDelete event doesn't see to be firing.
Using Entity Framework 4 with ApplicationBase
UMB 4.7.1
EF4
The type 'System.Data.Objects.ObjectContext' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.Data.Entity, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
Any insight?
The event should always fire do you have any code to show?
The Document.MoveToTrash event is what I shoild have handled. As this event fires first.
