  • Euan Rae 105 posts 135 karma points
    Mar 06, 2012 @ 11:48
    Euan Rae
    Using examine to index custom db tables
    I'm trying to use examine to index a custom db table.  I have created a custom Indexer class inheriting from LuceneIndexer, I've implemented 2 classes: "protected override void PerformIndexAll(string type)" and "protected override void PerformIndexRebuild()".
    In PerformIndexRebuild() I have got as far as creating 1 record (from another post that touched on the subject http://our.umbraco.org/forum/developers/extending-umbraco/22204-Examine-custom-indexer)
    var sds = new SimpleDataSet
                                  NodeDefinition = new IndexedNode(),
                                  RowData = new SerializableDictionary<string, string>()
                sds.NodeDefinition.NodeId = 1;
                sds.NodeDefinition.Type = "groupdId";
                sds.RowData.Add("groupName", "Sector Reports");
                sds.RowData.Add("groupItemsPerPage", "2");
                sds.RowData.Add("groupOnFeed", "0");
    // add the sds to some type of list here ???
    The issue is I don't know how to add it to the list that will ultimately used to be create the index.
    Also, as this index has nothing to do with umbraco data, when will the function to re-index be called?  And what is the difference between the PerformIndexAll and PerformIndexRebuild functions?
    Euan
