  • awm 187 posts 376 karma points
    Mar 08, 2012 @ 11:52
    awm
    Using ajax with surface controllers? (along with general surface controller questions)
    Hi guys,
    At the moment I'm trying to do something similar to Sebastiaan with his tutorial: http://cultiv.nl/blog/2011/11/15/creating-an-umbraco-5-package/
    The only difference is I'm trying to use ajax to post back my form data using the following:
    $.ajax({
      url: '/ContactSurface/SubmitForm',
      type: "POST",
      data: JSON.stringify(contactVM),
      contentType: "application/json; charset=utf-8",
      success: function (result) {
        $('#result').empty();
        $('#result').html(result);
      error: function () {
        $('#result').html("<p>There was a problem submitting your message. Please try again.</p>");
    Within my surface controller I then have the following function:
    [HttpPost]
    public PartialViewResult SubmitForm(ContactViewModel contactVM)
      if (!ModelState.IsValid)
        return PartialView("GetForm", contactVM);
      var contact = new Contact
        Name = contactVM.Name,
        Email = contactVM.Email,
        Message = contactVM.Message
      // Do whatever with new contact class
      return PartialView("Thankyou");
    Now before I tried to add this as a surface controller in umbraco, I did a standalone MVC3 project to test all the code and make sure it worked but now I'm trying to add it as a plugin, things aren't working.
    Before I proceed I'll mention that I'm still not entirely sure how the whole surface controller thing works with Umbraco. I've read Shannon's tutorial regarding surface controllers and while I understand how they work, I don't understand how it ties in with the CMS.
    From what I can see, it looks as though I have to add each function in my surface controller as a macro? In this test surface controller I've written I have two functions: one called GetForm() which returns a default view and the above SubmitForm() which is supposed to handle the posted form data. The code for the former is below:
    [ChildActionOnly]
    public PartialViewResult GetForm()
      return PartialView("GetForm", new ContactViewModel());
    What I've then done is to add my 'GetForm' and 'Thankyou' partial views to the Settings/Partials folder. I've then called the macro using: @Umbraco.RenderMacro("getForm") on my template.
    This /seems/ to have worked as the page is successfully calling my GetForm function and returning the view specified. However when I fill in this form and post it back, nothing happens. I think I'm posting back to the correct page using /ContactSurface/SubmitForm in the 'post' field of my first code segment but I'm not sure.
    I'm also unsure as to whether I have to register this function as a macro like I did with the GetForm() function. I realised I couldn't get the SubmitForm function to show in the macro dropdown unless I gave it the [ChildAction] attribute so I'm not really sure what I have to do here? What's the difference between a 'ChildAction' macro type and a 'Partial View' macro type?
    One final question, what are macro partials? I can't seem to find any documentation on them and have no idea how they fit in with everything. On top of this there's a 'Partials' folder in the settings tab but I'm guessing this is just for standard partial views?
    I realise this is a big post and appreciate any help that people can offer! I'm having a hard time understanding all these new terms :-)
    Thanks.
    Mar 13, 2012 @ 11:28
    awm
    bump
