I try to use 'base':
namespace My.Extensions.Base{ [RestExtension("baseProvider")] public class BaseProvider { [RestExtensionMethod()] public static string GetPostsByTag(int tagID, string selected) { StringBuilder html = new StringBuilder(); ... return html.ToString(); } }}
but when I write: http://localhost/base/baseProvider/GetPostsByTag/7/tag
I get
"NetworkError: 404 Not Found - http://localhost/base/baseProvider/GetPostsByTag/7/tag"
What am Imissing?
kukuwka
Hi. I'm not much of an expert in umbraco base but since it's a 404 error I suspect that your web.config misses the registration of the base http module (umbraco.presentation.umbracobase.requestModule).
Try to use the debug in url. Then you can see excately what Umbraco does
/base return 404 Not Found
I get
What am Imissing?
kukuwka
