  • Charles Ouellet 3 posts 23 karma points
    Apr 11, 2012 @ 14:34
    Charles Ouellet
    Problem with umbraco.MacroEngines.DynamicNode.ExecuteExtensionMethod
    We are having an issue with a fresh umbraco installation. We have built several apps over Umbraco CMS and it's the first time we are having this issue.
    I profiled the app using JetBrains DotTrace and I found that the method:
    umbraco.MacroEngines.DynamicNode.ExecuteExtensionMethod takes like 5 seconds to execute.
    Each request take about 20 seconds to run and 80% of the timespan is due to this method.
    As you can see, the method is executed about 200 times.
    There is alos a .ToList() that takes about 5 seconds too.
    Anyone has an hint about why it takes so long?
    Charles
    Apr 11, 2012 @ 14:36
    Charles Ouellet
    By the way this is a umbraco v 4.7.1.1 (Assembly version: 1.0.4393.24044) installation
  • De-eL 8 posts 29 karma points
    May 17, 2012 @ 00:53
    De-eL
    Charles, did you make any extension method calls to your dynamic objects in the razor script by any chance? Avoid such calls if possible ...
