Using more than one assembly in restExtensions.config
Can I use more than one assembly in base? I've tried adding each assembly and even swapping them around in the config file. Whichever one is specified first works while the second does not.
<error><![CDATA[MESSAGE: Object reference not set to an instance of an object. STACKTRACE: at umbraco.presentation.umbracobase.requestModule.invokeMethod(restExtension myExtension, Object[] paras) INNEREXCEPTION: ]]></error>
And updated my ajax call to "/base/BaseExtensions/CreateBlogComment" to "/base/BlogBaseExtensions/CreateBlogComment" instead, the method was being called properly.
I've found a better solution. I've removed the entries from restExtensions.config and put some rest attributes into my class instead.
[RestExtension("BaseExtensions")] public class BaseExtensions {
/// <summary> /// Creates a comment against a blog post. /// </summary> [RestExtensionMethod(allowType = "ActiveDirectoryMember")] public static string CreateBlogComment() { // all code is here } }
I think this is a better solution than using restExtenstions.config because:
1) I can use whatever alias I like and it doesn't appear to conflict with any other rest alias that might have been set by another package. i.e. in the example above my cBlog package is using the alias BaseExtensions and so is my cForum package.
2) Putting the attributes in the class itself means I don't have to alter the Umbraco site's restExtenstions.config, so there's no need to add a package install and uninstall action to update the file.
<RestExtensions>
<ext assembly="Umbraco.ChilliIS.cForum" type="Umbraco.ChilliIS.cForum.code.BaseExtensions" alias="BaseExtensions">
<permission method="CreateForumTopic" allowType="ActiveDirectoryMember" returnXML="false" />
<permission method="CreatePost" allowType="ActiveDirectoryMember" returnXML="false" />
<permission method="MarkReplyAsSolution" allowType="ActiveDirectoryMember" returnXML="false" />
<permission method="SubscribeToTopic" allowType="ActiveDirectoryMember" returnXML="false" />
<permission method="UnSubscribeToTopic" allowType="ActiveDirectoryMember" returnXML="false" />
</ext>
<ext assembly="Umbraco.ChilliIS.cBlog" type="Umbraco.ChilliIS.cBlog.code.BaseExtensions" alias="BaseExtensions">
<permission method="CreateBlogComment" allowType="ActiveDirectoryMember" returnXML="false" />
</ext>
</RestExtensions>
To be more precise, any call to the method in the second assembly, i.e. http://domain_name/base/BaseExtensions/CreateBlogComment returns a server 500 error containing this response:
I think I've found why I was a problem.
I used the same alias for both assemblies. Once I changed:
to:
<ext assembly="Umbraco.ChilliIS.cBlog" type="Umbraco.ChilliIS.cBlog.code.BaseExtensions" alias="BlogBaseExtensions">
/// <summary>
/// </summary>
// all code is here
If anyone has the same issue as myself, there's an example of using the attributes in the wiki at http://our.umbraco.org/wiki/reference/umbraco-base/simple-base-samples.
