Hello! I'm currently trying to create a custom tree and I'm running into trouble when trying to render a nodes children. After browsing various articles/posts I'm at this point:
The code above gets the article belonging to the current user (for the sake of testing, each user only has one article at the moment). I then attempt to print out the children of this article but instead of getting the desired output, I get the follwowing:
Article Name - Article Name - Article Name - Article Name
Each time I expand a node, it just seems to render the same node, and goes on and on.
I've seen other ways of using the treeservice, like:
xNode.Source=string.Format(IOHelper.ResolveUrl(SystemDirectories.Umbraco)+"/tree.aspx?rnd={0}&id={1}&treeType={2}&contextMenu={3}&isDialog={4}&isProduct=true",Guid.NewGuid(), categoryEntity.CategoryId,TreeAlias,ShowContextMenu,IsDialog); Could you explain a bit more about this?Many Thanks,
Yes xNode.Source is used to render children. When you try to open a child node "public override void Render(ref XmlTree tree)" is called again, but with different values. That's why I add "&isProduct=true" to the querystring and "&id={1}" is the id of the parent. It's a bit of a custom way and there are better ways to do it. This blog might help: http://www.robertgray.net.au/2011/5/27/creating-custom-multi-level-trees-in-umbraco.aspx
Multi-Level Custom Trees in 4.7
Hello!
public override void Render(ref XmlTree tree) { List<Node> articles = NodeUtil.GetAllNodesOfDocumentType(-1, "Promoter"); Node article = articles.Where(p => p.CreatorID == UmbracoEnsuredPage.CurrentUser.Id).FirstOrDefault(); if(promo != null) { var dNode = XmlTreeNode.Create(this); dNode.NodeID = article.Id.ToString(); dNode.Text = article.Name; dNode.Icon = "doc.gif"; dNode.Action = "javascript:openArticle(" + article.Id + ")"; dNode.Source = article.Children.Count > 0 ? this.GetTreeServiceUrl("" + article.Id) : ""; tree.Add(dNode); } }The code above gets the article belonging to the current user (for the sake of testing, each user only has one article at the moment). I then attempt to print out the children of this article but instead of getting the desired output, I get the follwowing:
Article Name
- Article Name
- Article Name
- Article Name
But I get an error saying there is no GetServiceUrl method that takes 0 arguments. I assume the method above was for earlier versions?
Any help would be greatly appreciated! Thanks
Here is the part of the code I used for creating a multi level custom tree. I hope it helps.
using System; using System.Collections.Generic; using System.Linq; using System.Reflection; using System.Text; using System.Web; using Project.BLL.Default; using Project.BLL.Utilities; using Project.DAL.CollectionClasses; using Project.DAL.EntityClasses; using Project.General.Default; using Project.Presentation.Layer; using Project.WebApplication.Sections.Products.Category; using Project.WebApplication.Sections.Products.Product; using umbraco.cms.presentation.Trees; using umbraco.interfaces; using umbraco.IO; namespace Project.WebApplication.Sections.Articles { public class LoadProductsTree : BaseTree { private ControllerLayer _controllerLayer; #region Properties public ControllerLayer ControllerLayer { get { if (_controllerLayer == null) { _controllerLayer = new ControllerLayer(); } return _controllerLayer; } } #endregion public LoadProductsTree(string application) : base(application) { } protected override void CreateRootNodeActions(ref List<IAction> actions) { //Remove the default actions. actions.Clear(); } protected override void CreateAllowedActions(ref List<IAction> actions) { //Remove the default actions. actions.Clear(); } protected override void CreateRootNode(ref XmlTreeNode rootNode) { //Create the root node. rootNode.Icon = "database_table.png"; rootNode.OpenIcon = "database_table.png"; rootNode.NodeType = TreeAlias; rootNode.Text = "Categories"; rootNode.NodeID = Constants.ROOTPATH; rootNode.Menu.Add(CreateCategoryAction.Instance); rootNode.Menu.Add(SortCategoryAction.Instance); } public override void Render(ref XmlTree tree) { //Check if the current tree is a product. string isProduct = HttpContext.Current.Request.QueryString["isProduct"]; if (string.IsNullOrEmpty(isProduct)) { //Get all the categories which will be displayed. CategoryCollection categoryCollection = ControllerLayer.GetCategories(); foreach (CategoryEntity categoryEntity in categoryCollection) { //Create the category node. XmlTreeNode xNode = XmlTreeNode.Create(this); xNode.NodeID = categoryEntity.CategoryId.ToString(); xNode.Text = categoryEntity.BackendName; xNode.Action = string.Format("javascript:openCategoryDetails('{0}');", categoryEntity.CategoryId); xNode.Icon = "table_multiple.png"; xNode.OpenIcon = "table_multiple.png"; xNode.Menu.Add(CreateProductAction.Instance); xNode.Menu.Add(DeleteCategoryAction.Instance); xNode.Menu.Add(SortProductAction.Instance); if (ControllerLayer.HasProducts(categoryEntity.CategoryId)) { //If the node has children show them. xNode.HasChildren = true; xNode.Source = string.Format(IOHelper.ResolveUrl(SystemDirectories.Umbraco) + "/tree.aspx?rnd={0}&id={1}&treeType={2}&contextMenu={3}&isDialog={4}&isProduct=true", Guid.NewGuid(), categoryEntity.CategoryId, TreeAlias, ShowContextMenu, IsDialog); } tree.treeCollection.Add(xNode); } } else if (isProduct == "true") { //Get the id of the category. int categoryId = this.id; //Get all the products which will be displayed. ProductCollection productCollection = ControllerLayer.GetProducts(categoryId); foreach (ProductEntity productEntity in productCollection) { //Create the product node. XmlTreeNode xNode = XmlTreeNode.Create(this); xNode.NodeID = productEntity.ProductId.ToString(); xNode.Text = productEntity.BackendName; xNode.Action = string.Format("javascript:openProductDetails('{0}');", productEntity.ProductId); xNode.Icon = "table_gear.png"; xNode.OpenIcon = "table_gear.png"; xNode.Menu.Add(DeleteProductAction.Instance); tree.treeCollection.Add(xNode); } } } public override void RenderJS(ref StringBuilder Javascript) { //Opens the category details page. Javascript.Append( @" function openCategoryDetails(id) { parent.right.document.location.href = '" + IOHelper.ResolveUrl(SystemDirectories.Umbraco) + @"/customSections/products/CategoryDetails.aspx?id=' + id; } "); //Opens the product details page. Javascript.Append( @" function openProductDetails(id) { parent.right.document.location.href = '" + IOHelper.ResolveUrl(SystemDirectories.Umbraco) + @"/customSections/products/ProductDetails.aspx?id=' + id; } "); } } }Jeroen
Hi Jeroen,
Thanks for your response.
Is the main part for rendering children this:
xNode.Source=string.Format(IOHelper.ResolveUrl(SystemDirectories.Umbraco)+"/tree.aspx?rnd={0}&id={1}&treeType={2}&contextMenu={3}&isDialog={4}&isProduct=true",Guid.NewGuid(), categoryEntity.CategoryId,TreeAlias,ShowContextMenu,IsDialog); Could you explain a bit more about this?Many Thanks,Yes xNode.Source is used to render children. When you try to open a child node "public override void Render(ref XmlTree tree)" is called again, but with different values. That's why I add "&isProduct=true" to the querystring and "&id={1}" is the id of the parent. It's a bit of a custom way and there are better ways to do it. This blog might help: http://www.robertgray.net.au/2011/5/27/creating-custom-multi-level-trees-in-umbraco.aspx
Jeroen
Hi Jeroen,
Thanks for that! Seems like it should do the trick. Im away from my computer for a few days then will give it a try!
