Not sure if I'm posting in the right place.. but anyway..
I have installed Eksponent CropUp 0.9 on a 4.7.2 installation and can successfully create the data type, set up the config for CropUp and attach the data type to my media type. The problem is when I navigate to a media item, I get an object reference not set error (see below). Has anyone run into this problem or have a fix for it?
Braydie
Source Error:
Stack Trace:
Eksponent.CropUp.CropUpModule.get_ImageUrlPrefix() +111
Eksponent.CropUp.CropUpModule..cctor() +37
[TypeInitializationException: The type initializer for 'Eksponent.CropUp.CropUpModule' threw an exception.]
Eksponent.CropUp.CropUpModule.GetImageUrl(String imagePath, ImageSizeArguments args, String metaData, ImageCropData data) +0
Eksponent.CropUp.UmbracoIV.Cropper.OnPreRender(EventArgs e) +664
System.Web.UI.Control.PreRenderRecursiveInternal() +103
System.Web.UI.Control.PreRenderRecursiveInternal() +175
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2496
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
Eksponent CropUp problems
Braydie
Source Error:
Turns out I hadn't updated my web.config as per the instructions on the codeplex site.
http://cropup.codeplex.com/
D'oh!
